Подшипники колесные
октября 19, 2026, 12:29:33 *
Страниц: 1 ... 9 10 [11]   Вниз
Автор Тема: Подшипники колесные  (Прочитано 36253 раз)
ocivan
honda
« Ответ #150 : декабря 03, 2023, 09:31:51 »
Work Environment: If the bearing is going to operate in high-temperature conditions, such as near a vehicle engine, C3 bearings may be more suitable.
Sealing Requirements: If the bearing is located in a place prone to dust and moisture, 2RS seals can provide better protection.
Bearing Load: Choose the appropriate bearing model based on the actual load and working conditions.
https://www.tradebearings.com/
Страниц: 1 ... 9 10 [11]   Вверх
